[gdal-dev] SDE raster driver: vertical displacement of 64 pixels
Howard Butler hobu.inc at gmail.com
Wed Dec 5 12:07:37 EST 2007
Duarte,
I have looked into this issue a couple of different times as you have
reported it, but I have been simply unable to reproduce the issue.
Could you please file a ticket in Trac with the exact steps that I can
use to reproduce the issue?  Once you file the ticket, I will provide
connection details to my ArcSDE instance so you can upload a raster to
my server that I can use to reproduce.
Thanks,
Howard
On Dec 5, 2007, at 8:51 AM, Duarte Carreira wrote:
> Hello all.
> I've just tested gdal's sde driver to export a geographic window
> from a ArcSDE raster dataset, using the -projwin option. I tested
> against ArcSDE 9.2 SP3, on Oracle 92, using FWTools 1.3.9 containing
> GDAL 1.5dev.
> I measured the distance between the original and the exported image
> and got 64 pixels vertical, 0 horizontal.
> The raster dataset is 0,4m / pixel, and the raster tile dimension is
> 128x128 pixels. Could it be something to do with the tile size? But
> 128x128 is the default value.
> This is the same problem I reported a few months back.
> Any possible help on this?
> Regards,
> Duarte Carreira
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
