[gdal-dev] Python documentation help
Howard Butler hobu.inc at gmail.com
Wed Dec 5 16:32:37 EST 2007
On Dec 5, 2007, at 3:03 PM, Lucena, Ivan wrote:
> Howard,
> I thing I've got it!
> Howard Butler wrote:
>> hmm... Where could it be picking up the old-gen gdal.py from?  The
>> setup.py script in ./swig/python doesn't make reference to anything
>> in ./pymod, the ./swig/python/gdal.py *is* the simple wrapper as
>> expected, and setup.cfg doesn't point to ./pymod either.
> My ./swig/python/gdal.py was wrong because it was generated by SWIG.
> So I got the right gdal.py (with just a few lines) and I run
> setup.py bdist_wininst again and everything is fine now. See:
> >>> import gdal
> C:\Program Files\Python24\lib\site-packages\osgeo\gdal.py:81:
> DeprecationWarning: gdal.py was placed in a namespace, it is now
> available as osgeo.gdal
>  DeprecationWarning)
> >>> gdal.AllRegister()
> If I start over and compile SWIG Python then I've got the same
> problem.
> I run:
> cd swig
> nmake -f makefile.vc python
> And that re-creates the gdal.py. The bigger/wrong one.
> Well, I hope that whole discussion would help you in some way... :)
Ivan,
Thanks, that was very helpful.  The windows makefile hadn't been
updated to put its output in the osgeo directory and it was stomping
over the simple wrappers.
http://trac.osgeo.org/gdal/changeset/13266
Howard
