[gdal-dev] Python documentation help
Lucena, Ivan
ivan.lucena at pmldnet.com
Wed Dec 5 15:00:34 EST 2007
Howard, Chris,
Howard Butler wrote:
> On Dec 5, 2007, at 11:55 AM, Christopher Barker wrote:
>> Lucena, Ivan wrote:
>>> Note: I tried the old import and the new one just to make sure.
>>> >>> import gdal
>>> Traceback (most recent call last):
>>> File "<interactive input>", line 1, in ?
>>> File "C:\Progra~1\Python24\Lib\site-packages\gdal.py", line 6, in ?
>>> import _gdal
>>> ImportError: No module named _gdal
>> umm, isn't that a bug? I thought we were keeping it backward
>> compatible (with a deprecation warning) for this release.
> Ivan,
> I suspect that C:\Progra~1\Python24\Lib\site-packages\gdal.py is and
> old-generation gdal.py in the way. If you open it up and it is more
> than 10 lines of code, this is probably the case. Did you install the
> old-generation stuff *after* installing the next-generation?
No, I didn't. I am sure that I have done that a long time *before* but
not after. And yes, the gdal.py has more than 10 lines of code. A lot
more. So let me start over and see what happens:
On "Add or Remove Programs" I remove "Python 2.4 GDAL-1.5.0.a.dev":
Uninstall Finished!
42 files and 1 directories removed
OK
Now python doesn't have GDAL anymore:
>>> import gdal
ImportError: No module named gdal
There is no osgeo folder or any gdal*.* or ogr*.* file on site-packages.
So I run GDAL-1.5.0.a.dev.win32-py2.4.exe again and just after that I try:
>>> import gdal
import _gdal
I guess that what you would expect is that \Lib\site-packages\gdal.py
would be smaller, just a wrapper to call the osgeo\gdal.py.
But again *before* running the GDAL Python Installer I have no gdal.py
and just *after* running it I have a big one and I got an error when
using "import gdal" but I have no problem using "from osgeo import gdal".
I am going to try later in another computer with a fresh Python
installation to see what happen and I will not going to run SWIG this
time, OK?
Anyway, I think we should add a Windows section on that wiki page. What
do you think?
Best regards,
Ivan
