[gdal-dev] FW: Converting Geomedia Terrain ASCII files to geotif
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Wed Dec 5 19:09:43 EST 2007
Hello All,
I am looking for a way to convert Geomedia Terrain ASCII files to geotif. Below is an example of what this file looks like. It is a NAD27 California State Plane Zone 3 file. People have suggested that I strip the header and use a VRT to do this, but the docs seem to suggest that it does not work with ASCII data. Any other ideas?
Thanks in advance,
Bob
ASCII Z GRID
XORIGIN=480438.521976
YORIGIN=141096.092712
NUMROWS=532
NUMCOLUMNS=876
ROWSPACING=30.48
COLUMNSPACING=30.48
SCANORIGIN=TL
ORDER=row
VUOM=ft
VOID=-9999
VERTICALDATUM=NAVD88
-9999
-9999
-9999
-9999
[ NUMROWS x NUMCOLUMNS 'th row]
Bob Moskovitz
Seismic Hazard Zonation Project
California Geological Survey
http://www.conservation.ca.gov/cgs/shzp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071205/e99c9db3/attachment-0001.html
