[gdal-dev] FW: Converting Geomedia Terrain ASCII files to geotif
Frank Warmerdam
warmerdam at pobox.com
Wed Dec 5 19:43:10 EST 2007
Moskovitz, Bob wrote:
> Hello All,
> I am looking for a way to convert Geomedia Terrain ASCII files to
> geotif. Below is an example of what this file looks like. It is a
> NAD27 California State Plane Zone 3 file. People have suggested that I
> strip the header and use a VRT to do this, but the docs seem to suggest
> that it does not work with ASCII data. Any other ideas?
> Thanks in advance,
> Bob
> ASCII Z GRID
> XORIGIN=480438.521976
> YORIGIN=141096.092712
> NUMROWS=532
> NUMCOLUMNS=876
> ROWSPACING=30.48
> COLUMNSPACING=30.48
> SCANORIGIN=TL
> ORDER=row
> VUOM=ft
> VOID=-9999
> VERTICALDATUM=NAVD88
> -9999
> -9999
> -9999
> -9999
> [ NUMROWS x NUMCOLUMNS 'th row]
Bob,
You could replace the header portion with the header lines for an
ESRI ASCII Grid.
eg.
NCOLS 170
NROWS 148
CELLSIZE 40
XLLCENTER 1724520
YLLCENTER 5125840
NODATA_VALUE -9999
1518.621 1410.902 1290.767 1236.527...
I think the AAIGRID pixel values are one text line per scanline
but I don't think the reader code cares about what kind of white
space appears between pixel values so it should work. Well, I'm not
absolutely sure of that.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
