[Gdal-dev] WMS with C# Bindings
Tamas Szekeres
szekerest at gmail.com
Thu Dec 6 12:25:39 EST 2007
I couldn't follow exactly what is the issue. Do you have and error
message? Could you post a code sample to reproduce the problem?
Best regards,
Tamas
2007/12/6, GrinderDev <grinderprogrammer at gmail.com>:
> >The filename shouldn't matter. The thing that matters is that the first
> >characters in the file are:
> > <GDAL_WMS>
> I verified that this was indeed the first characters in the file.
> > Also, are you sure your GDAL library supports WMS requests?
> I checked the library and it does indeed support WMS. I'm using
> FWTools2.0.2
> Perhaps this is a C# binding issue?
> View this message in context: http://www.nabble.com/WMS-with-C--Bindings-tf4956367.html#a14195862
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
