[Gdal-dev] WMS with C# Bindings
Adam Nowacki
nowak at xpam.de
Thu Dec 6 13:21:32 EST 2007
GrinderDev wrote:
> Tamas Szekeres wrote:
>> I couldn't follow exactly what is the issue. Do you have and error
>> message? Could you post a code sample to reproduce the problem?
> The error: "Couldn't load dataset, 'd:\wms_test\gdal_tes.wms' no recognised
> as a supported file format.
You sure you're just not missing a 't' there? If not attach your xml
config file.
