[gdal-dev] building gdal1.5 and apps makefile.vc
Howard Butler
hobu.inc at gmail.com
Tue Dec 11 21:50:13 EST 2007
Michael,
I'm a bit confused, but I think you are attempting to build a
gdal15.dll that can be used with the windows egg files on PyPI...
correct?
If so, you should only have to build GDAL itself, not anything in ./
swig/python. setup.py and the makefile.vc in ./swig are only related
to building and generating the bindings. You shouldn't have to mess
with this stuff if you are planning to use the PyPI packages...
I don't know about the apps makefile.vc. Maybe this is out of date
for some reason?
On Dec 11, 2007, at 6:13 PM, Michael ODonnell wrote:
> Third, the files that were included in the gdal-1.5.0b2 redirected
> the gdal to osgeo directory. Is it possible to set my path to osgeo
> rather than being redirected.
Can you provide more detail here? I don't quite know what you mean by
"redirected"
Howard
