[gdal-dev] Building Gdal 1.5 beta on a 64 bit system
Steve Popovich cartrite1 at yahoo.com
Wed Dec 12 17:27:57 EST 2007
Frank Warmerdam <warmerdam at pobox.com> wrote: Steve Popovich wrote:
> Frank Warmerdam wrote:
> Are you possibly using an external libtiff?
> Yes I was. I rebuilt with ./configure --without-libtool --with-python --with-libtiff=internal
> and the autotest results were:
>  ------------ Failures ------------
> Script: ogr/ogr_geom.py
>   TEST: ogr_geom_empty ... fail
>     IsEmpty returning false for an empty geometry
Steve,
I doubt the above is significant.  I think the autotest is just a bit out of
sync with the 1.4 branch behavior.
OK
> I'm new to this environment and never did a trac ticket so I'll have to look into it.
> For now I'll try to add a little more info.
> I built gdal-1.4.4 with a standard devel installation on openSuse10.2 x86_64.
> This is the first time I tried to build something and had to install extra deps.
> The first link error was with LibSM.la. I had that file in /usr/lib64 but not /usr/lib
> I installed xorg-x11-libSM-devel-32bit and got past that link error only to fail at the next.
It is not at all clear to me why GDAL would have a dependency on X11 stuff
like libSM.  BTW, were you deliberately trying to build 32bit executables?
I also don't understand why 32bit versions of stuff would be needed.
I posted the original error that was on the terminal output here. http://trac.osgeo.org/gdal/wiki/TestMatrix150
I wasn't trying to do anything special. I still get the error by using just ./configure. The libtool that is being generated is linking to the wrong libs. I only installed the 32bit devel files because I wanted to see what would happen if the file was in the folder that the linker was looking in.
> I then installed all the x11-devel-32bit files and then failed linking to libidn.
> openSuse10.2 does not have a 32bit devel package for libidn so I gave up.
> That is when I configured --without-libtool and everything worked.
> This is the first time in all the pkgs I built over the last 4 years that I had to build
> with the --without-libtool option. As you can
>  see from above that it works but is this
> acceptable or is something wrong with libtool creation?
When things get messy, I build --without-libtool.  It works fine in
normal situations, but it seems fragile.  (IMHO)
The only thing that bothers me is that this probably shouldn't be happening. If it happens to me it will probably happen to others too.
Steve
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
Be a better friend, newshound, and know-it-all with Yahoo! Mobile.  Try it now.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071212/8db19ade/attachment-0001.html
