[gdal-dev] Questions about OGR ArcSDE Driver
Frank Warmerdam
warmerdam at pobox.com
Mon Dec 17 14:21:54 EST 2007
Bob Cave wrote:
> 1) The current documentation for the OGR ESRI ArcSDE driver states:
> "Curve geometries are approximated as line strings (actually still
> TODO)." Is this item still a "TODO" item? If so, how long might it be
> until it is completed? How are curve objects represented until the
> curve-to-line functionality is implemented?
Bob,
It is still "TODO". I'm not exactly sure what happens to curves.
I suspect they just result in reports of the following warning:
CPLError( CE_Warning, CPLE_NotSupported,
"Unsupported geometry type: %d",
nSDEGeomType );
and the production of features with no geometry at all.
> 2) Does this driver require an ArcSDE client license of some sort?
I'm a bit unclear on this. You do need the ArcSDE client libraries and the
normal way to get them is to have an ArcSDE license. I believe that while
you are connected to SDE you are tying up an SDE client license depending
on the licensing mechanism you are using for SDE.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
