[gdal-dev] Projections & Datums
Frank Warmerdam
warmerdam at pobox.com
Wed Dec 19 14:48:51 EST 2007
Chris Howell wrote:
> Is there a documented list somewhere that outlines the projections and
> datums that GDAL knows about ? I've seen reference to some in the code
> on GDAL trac but I haven't been able to find a good list documented
> somewhere
Chris,
The list of projection methods in theory understood by GDAL is defined by
the methods for setting them on OGRSpatialReference:
/** Albers Conic Equal Area */
OGRErr SetACEA( double dfStdP1, double dfStdP2,
double dfCenterLat, double dfCenterLong,
double dfFalseEasting, double dfFalseNorthing );
/** Azimuthal Equidistant */
OGRErr SetAE( double dfCenterLat, double dfCenterLong,
/** Bonne */
OGRErr SetBonne( double dfStdP1, double dfCentralMeridian,
/** Cylindrical Equal Area */
OGRErr SetCEA( double dfStdP1, double dfCentralMeridian,
/** Cassini-Soldner */
OGRErr SetCS( double dfCenterLat, double dfCenterLong,
/** Equidistant Conic */
OGRErr SetEC( double dfStdP1, double dfStdP2,
/** Eckert I-VI */
OGRErr SetEckert( int nVariation, double dfCentralMeridian,
OGRErr SetEckertIV( double dfCentralMeridian,
OGRErr SetEckertVI( double dfCentralMeridian,
/** Equirectangular */
OGRErr SetEquirectangular(double dfCenterLat, double dfCenterLong,
/** Geostationary Satellite */
OGRErr SetGEOS( double dfCentralMeridian, double dfSatelliteHeight,
/** Goode Homolosine */
OGRErr SetGH( double dfCentralMeridian,
/** Gall Stereograpic */
OGRErr SetGS( double dfCentralMeridian,
/** Gnomonic */
OGRErr SetGnomonic(double dfCenterLat, double dfCenterLong,
OGRErr SetHOM( double dfCenterLat, double dfCenterLong,
double dfAzimuth, double dfRectToSkew,
double dfScale,
OGRErr SetHOM2PNO( double dfCenterLat,
double dfLat1, double dfLong1,
double dfLat2, double dfLong2,
double dfScale,
/** Krovak Oblique Conic Conformal */
OGRErr SetKrovak( double dfCenterLat, double dfCenterLong,
double dfAzimuth, double dfPseudoStdParallelLat,
double dfScale,
/** Lambert Azimuthal Equal-Area */
OGRErr SetLAEA( double dfCenterLat, double dfCenterLong,
/** Lambert Conformal Conic */
OGRErr SetLCC( double dfStdP1, double dfStdP2,
/** Lambert Conformal Conic 1SP */
OGRErr SetLCC1SP( double dfCenterLat, double dfCenterLong,
double dfScale,
/** Lambert Conformal Conic (Belgium) */
OGRErr SetLCCB( double dfStdP1, double dfStdP2,
/** Miller Cylindrical */
OGRErr SetMC( double dfCenterLat, double dfCenterLong,
/** Mercator */
OGRErr SetMercator( double dfCenterLat, double dfCenterLong,
double dfScale,
OGRErr SetMercator2SP( double dfStdP1,
/** Mollweide */
OGRErr SetMollweide( double dfCentralMeridian,
/** New Zealand Map Grid */
OGRErr SetNZMG( double dfCenterLat, double dfCenterLong,
/** Oblique Stereographic */
OGRErr SetOS( double dfOriginLat, double dfCMeridian,
double dfScale,
double dfFalseEasting,double dfFalseNorthing);
/** Orthographic */
OGRErr SetOrthographic( double dfCenterLat, double dfCenterLong,
/** Polyconic */
OGRErr SetPolyconic( double dfCenterLat, double dfCenterLong,
/** Polar Stereographic */
OGRErr SetPS( double dfCenterLat, double dfCenterLong,
double dfScale,
double dfFalseEasting, double dfFalseNorthing);
/** Robinson */
OGRErr SetRobinson( double dfCenterLong,
/** Sinusoidal */
OGRErr SetSinusoidal( double dfCenterLong,
/** Stereographic */
OGRErr SetStereographic( double dfCenterLat, double dfCenterLong,
double dfScale,
/** Swiss Oblique Cylindrical */
OGRErr SetSOC( double dfLatitudeOfOrigin, double dfCentralMeridian,
/** Transverse Mercator */
OGRErr SetTM( double dfCenterLat, double dfCenterLong,
double dfScale,
/** Transverse Mercator variants. */
OGRErr SetTMVariant( const char *pszVariantName,
double dfScale,
/** Tunesia Mining Grid */
OGRErr SetTMG( double dfCenterLat, double dfCenterLong,
/** Transverse Mercator (South Oriented) */
OGRErr SetTMSO( double dfCenterLat, double dfCenterLong,
double dfScale,
/** Two Point Equidistant */
OGRErr SetTPED( double dfLat1, double dfLong1,
/** VanDerGrinten */
OGRErr SetVDG( double dfCenterLong,
/** Universal Transverse Mercator */
OGRErr SetUTM( int nZone, int bNorth = TRUE );
int GetUTMZone( int *pbNorth = NULL ) const;
/** State Plane */
OGRErr SetStatePlane( int nZone, int bNAD83 = TRUE,
const char *pszOverrideUnitName = NULL,
double dfOverrideUnit = 0.0 );
The datums supported is not really listable as datum support is mostly
parametric. That is if you want datum shifts you need to provide the
TOWGS84[] parameters you want to use. There are a few special "builtin"
cases, including special handling of NAD27.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
