[gdal-dev] 1.5.0b2 geotiff and 1-bit compression..
Frank Warmerdam
warmerdam at pobox.com
Thu Dec 20 18:12:20 EST 2007
Cicconetti, Bob wrote:
> Something appears to have broken creation of 1-bit Geotiffs relatively
> recently.. It works with the 1.5dev snapshot included with QGIS, and
> with 1.4.2.0, but fails with FWTools2.03 and the beta2 binaries for Win32.
> $ /cygdrive/c/Program\ Files/FWTools2.0.3/bin/gdal_translate.exe -co
> NBITS=1 -co COMPRESS=PACKBITS worc_test21.img worc_test22.tif
> Input file size is 363341, 362736
> 0ERROR 1: One bit raster bands are read-only.
> It does produce an output file, but it is completely blank.
> worc_test21.img is a ~16GB, 1-bit HFA file. Quite sparse.. compresses
> down to about 250 MB with CCITT FAX4. Not something I can distribute as
> test material, though.
Bob,
I have confirmed the problem and filed it as:
http://trac.osgeo.org/gdal/ticket/2115
I will fix it this evening and I suspect we will need to issue a new RC
including the fix.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
