[gdal-dev] gdalwarp: ERROR 1: TIFFFetchStripThing:Sanity check on
size of "StripOffsets" value failed
John Mitchell
mitchelljj98 at gmail.com
Thu Dec 27 09:20:40 EST 2007
When running the below command:
gdalwarp.exe --config GDAL_CACHEMAX 250 -wm 250 -wo SKIP_NOSOURCE=YES -tr
1.1994660564E-5 1.1994660564E-5 -srcnodata "0 0 0" -dstnodata "0 0 1" -rc
-s_srs EPSG:26911 -t_srs EPSG:4326 -co bigtiff=yes -q --optfile
x:\ProcessingControl\gvwkr02\gvApp2\tmp\inputFiles.txt
"x:\ProcessingControl\gvwkr02\gvApp2\tmp\mosaic_0_161039.tiftemp"
I get the following error:
ERROR>ERROR 1: TIFFFetchStripThing:Sanity check on size of "StripOffsets"
value failed
I have run similar gdalwarp commands against other datasets and have not had
this error. Also when I run gdalwarp against each one of these files
(that x:\ProcessingControl\gvwkr02\gvApp2\tmp\inputFiles.txt
is referencing) individually I get no error.
Any ideas on what this error means?
Do I have to split up the above gdalwarp mosaicking process into 2 parts and
then mosaic then back together in order to get around this error, or would
increasing the RAM, hard drive space, etc. help to get around this error?
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071227/bc19004d/attachment.html
