[gdal-dev] Re: gdalwarp: ERROR 1: TIFFFetchStripThing:Sanity check
on size of "StripOffsets" value failed
John Mitchell
mitchelljj98 at gmail.com
Thu Dec 27 10:39:35 EST 2007
It appears that the below error is not preventing the gdalwarp processing
from running but is the below error something to be concerned about?
Thanks,
John
On Dec 27, 2007 9:20 AM, John Mitchell <mitchelljj98 at gmail.com> wrote:
> Hi,
> When running the below command:
> gdalwarp.exe --config GDAL_CACHEMAX 250 -wm 250 -wo SKIP_NOSOURCE=YES -tr
> 1.1994660564E-5 1.1994660564E-5 -srcnodata "0 0 0" -dstnodata "0 0 1" -rc
> -s_srs EPSG:26911 -t_srs EPSG:4326 -co bigtiff=yes -q --optfile
> x:\ProcessingControl\gvwkr02\gvApp2\tmp\inputFiles.txt
> "x:\ProcessingControl\gvwkr02\gvApp2\tmp\mosaic_0_161039.tiftemp"
> I get the following error:
> ERROR>ERROR 1: TIFFFetchStripThing:Sanity check on size of "StripOffsets"
> value failed
> I have run similar gdalwarp commands against other datasets and have not
> had this error. Also when I run gdalwarp against each one of these files
> (that x:\ProcessingControl\gvwkr02\gvApp2\tmp\inputFiles.txt is
> referencing) individually I get no error.
> Any ideas on what this error means?
> Do I have to split up the above gdalwarp mosaicking process into 2 parts
> and then mosaic then back together in order to get around this error, or
> would increasing the RAM, hard drive space, etc. help to get around this
> error?
> Thanks,
> John J. Mitchell
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20071227/7129f07f/attachment.html
