[Gdal-dev] compiled GDAL files don't work
Ivan Lucena
ivan at ilucena.net
Fri Feb 2 10:08:43 EST 2007
Have you try the Visual Studio 2003/5 Solution "makegdal.sln" from the
GDAL SVN repository?
----- Original Message -----
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] compiled GDAL files don't work
Date: Fri, 02 Feb 2007 15:51:03 +0100
Hi I did exactly as explained on
http://vterrain.org/Distrib/gdal.html and i finally managed to
compile everythingIt just doesn't work. I tried the gdalwarp.exe but
even when i call it using only -h it just crashes..... Can anyone
help me with that? Thanks in advance
__________________________________________________
Institut für Mensch-Maschine-Interaktion RWTH Aachen
Dipl.-Ing. Petra Maria Krahwinkler
Ahornstrasse 55
52074 Aachen
Germany
Fon: +49 241 80-23635
Fax: +49 241 80-22308
mailto:Krahwinkler at mmi.rwth-aachen.de
http://www.mmi.rwth-aachen.de
Der Inhalt dieser E-Mail ist ausschliesslich fuer den bezeichneten
Adressaten bestimmt. Jede Form der Kenntnisnahme,
Veroeffentlichung,Vervielfaeltigung oder Weitergabe des Inhalts
dieser E-Mail durch unberechtigte Dritte ist unzulaessig.
Falls Sie nicht der Adressat dieser E-Mail sind, bitten wir Sie, das
Material von Ihrem Computer zu loeschen und sich mit dem Absender in
Verbindung zu setzen.
This e-mail and any attachments are confidential and intended solely
for the addressee. The perusal, publication, copying or dissemination
of the contents of this e-mail by unauthorised third parties is
prohibited. If you are not the intended recipient of this e-mail,
please delete it and immediately notify the sender.
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070202/edfb14b9/attachment.html
