[Gdal-dev] compiled GDAL files don't work
Daniele Romagnoli
dany.geotools at gmail.com
Fri Feb 2 11:26:33 EST 2007
Hi Petra
What do you mean with "it just crashes"?
Can you provide more information about that? (errors, messages, logs or
something similar).
Best Regards,
Daniele
On 2/2/07, Petra Krahwinkler <Krahwinkler at mmi.rwth-aachen.de> wrote:
> Hi
> I did exactly as explained on http://vterrain.org/Distrib/gdal.html and i
> finally managed to compile everything
> It just doesn't work. I tried the gdalwarp.exe but even when i call it
> using only -h it just crashes.....
> Can anyone help me with that?
> Thanks in advance
> *__________________________________________________*
> Institut für Mensch-Maschine-Interaktion RWTH Aachen
> Dipl.-Ing. Petra Maria Krahwinkler
> Ahornstrasse 55
> 52074 Aachen
> Germany
> Fon: +49 241 80-23635
> Fax: +49 241 80-22308
> mailto:Krahwinkler at mmi.rwth-aachen.de <Krahwinkler at mmi.rwth-aachen.de>
> *http://www.mmi.rwth-aachen.de * <http://www.mmi.rwth-aachen.de/>
> Der Inhalt dieser E-Mail ist ausschliesslich fuer den bezeichneten
> Adressaten bestimmt. Jede Form der Kenntnisnahme,
> Veroeffentlichung,Vervielfaeltigung oder Weitergabe des Inhalts dieser
> E-Mail durch unberechtigte Dritte ist unzulaessig.
> Falls Sie nicht der Adressat dieser E-Mail sind, bitten wir Sie, das
> Material von Ihrem Computer zu loeschen und sich mit dem Absender in
> Verbindung zu setzen.
> This e-mail and any attachments are confidential and intended solely for
> the addressee. The perusal, publication, copying or dissemination of the
> contents of this e-mail by unauthorised third parties is prohibited. If you
> are not the intended recipient of this e-mail, please delete it and
> immediately notify the sender.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070202/5e0b1185/attachment.html
