[Gdal-dev] Does gdalinfo Bounding Box Information really match
DTED / SRTM ?
Michael84
michael.timo.welsch at gmx.de
Sun Feb 4 09:59:24 EST 2007
Thank you very much. Is there no GDAL function to have a "point" view of
GDALDataSet ?
Frank Warmerdam-2 wrote:
> Michael84 wrote:
>> I use gdalinfo to extract bounding box information of DTED L0&L1 (dt0,
>> dt1)
>> as well as SRTM (hgt over bil+hdr+proj solution) data.
>> In both cases the reported corner points are not integer values as
>> supposed.
>> Corner Coordinates: (DTED)
>> Upper Left ( -0.0041667, 49.0041667) ( 0d 0'15.00"W, 49d 0'15.00"N)
>> Lower Left ( -0.0041667, 47.9958333) ( 0d 0'15.00"W, 47d59'45.00"N)
>> Upper Right ( 1.0041667, 49.0041667) ( 1d 0'15.00"E, 49d 0'15.00"N)
>> Lower Right ( 1.0041667, 47.9958333) ( 1d 0'15.00"E, 47d59'45.00"N)
>> Center ( 0.5000000, 48.5000000) ( 0d30'0.00"E, 48d30'0.00"N)
>> Is this is a roundig bug of gdal or are the data sources just coded like
>> this ?
> Michael,
> GDAL treats pixels are representing an area, and the bounds of a raster
> are the bounds of the outer edges of the pixel region.
> DTEDs however are normally thought of as samples at points (with a pixel
> sometimes drawn around that point to represent it). When thought of as
> point data DTED corners are right on 1 degree cell boundaries.
> So this is the class "pixel as area" vs. "pixel as point" discrepency
> which results in an off-by-one-half-pixel difference under various
> circumstances.
> So, there is no bug, only differences in interpretation of what the
> bounds of a raster are.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo, http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
View this message in context: http://www.nabble.com/Does-gdalinfo-Bounding-Box-Information-really-match-DTED---SRTM---tf3140934.html#a8793494
Sent from the GDAL - Dev mailing list archive at Nabble.com.
