[Gdal-dev] gdaladdo with .rrd ignoring compress overviews?
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Feb 6 19:21:17 EST 2007
Hi gdal, I'm on roll today! Here's another one: Why does gdalinfo report
that overviews are compressed with RLC when I asked for LZW? Can only
one --config option be used at a time? Or does .rrd not support choice
of compression?
gdaladdo --config use_rrd yes --config compress_overview lzw -r
nearest 094M.tif 2 4 8 16 32
gdalinfo 094M.aux
Driver: HFA/Erdas Imagine Images (.img)
Size is 5817, 5714
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 5714.0)
Upper Right ( 5817.0, 0.0)
Lower Right ( 5817.0, 5714.0)
Center ( 2908.5, 2857.0)
Band 1 Block=64x64 Type=Byte, ColorInterp=Undefined
Description = Layer_1
Overviews: 2909x2857, 1455x1429, 728x715, 364x358, 182x179
Metadata:
LAYER_TYPE=athematic
Image Structure Metadata:
COMPRESSION=RLC
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
