[Gdal-dev] packbits compression no good for 16bit?
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Feb 7 11:40:55 EST 2007
> I believe that packbits compression is applied byte by byte.  If your
> nodata areas use a 16bit value where the high order and low order byte
> are different then there will essentially be no "runs" for the packbits
> compression scheme to compress.  I think you would find it does a great
> deal better if your nodata value was something like 0.
> Packbits is very simple minded.
Thank you for the peek under the hood. At least I have an idea of what
is (not) happening now. I'll stick with lzw compression for now.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
