[Gdal-dev] packbits compression no good for 16bit?
Tue Feb 6 23:37:56 EST 2007
Matt Wilkie wrote:
> Hi GDAL,
> I seem to be having a really bad stretch of gdal oddities this month :)
> Here is the next installment:
> When compressing a 22mb 16bit geotiff using packbits compression I only
> get a 1% reduction in filesize. Is this expected? The source image is
> 7/8ths nodata so I think I should easily get greater than 90%
> compression. I get the same results with fwtools 1.1.4 and 1.2.0 on two
> machines, both running WinXPsp2.
>    for %a in (deflate lzw none packbits) do (
>     gdal_translate -co compress=%a source.tif compress_%a.tif
>    dir *.tif
>      4,810,097 source.tif
>      1,225,395 compress_deflate.tif
>      1,977,859 compress_lzw.tif
>     23,073,871 compress_none.tif
>     22,456,093 compress_packbits.tif
Matt,
I believe that packbits compression is applied byte by byte.  If your
nodata areas use a 16bit value where the high order and low order byte
are different then there will essentially be no "runs" for the packbits
compression scheme to compress.  I think you would find it does a great
deal better if your nodata value was something like 0.
Packbits is very simple minded.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
