[Gdal-dev] Block size consistency (and SetColorInterpretation() in GTiff)
Wed Feb 7 19:21:48 EST 2007
Ozy Sjahputera wrote:
> Aha, so there is a way to set the photometric interpretation in GTiff,
> even if this is to be done during file creation.   Yes, I just want to
> give a simple label for the bands in the new GTiff file I created using
> Create().
> I suspect the PHOTOMETRIC=RGB will have to be set in the parameter
> char **  /papszParmList
> /in Create()?  Where do I set this parameter?   Where can I find more
> details on the format of /papszParmList?/
Ozy,
It is a NULL terminated list of strings.  So something like:
   char *apszParmList[] = { "PHOTOMETRIC=RGB", NULL };
will do the trick.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
