[Gdal-dev] Block size consistency (and SetColorInterpretation()
in GTiff)
Ozy Sjahputera
sjahputerao at missouri.edu
Wed Feb 7 17:01:24 EST 2007
Thanks for the tip, Frank.
I would like to create an image with 5 bands in the order of: Pan, R, G,
B, NIR.
How would PHOTOMETRIC=RGB affect the band photometric interpretation?
Can I implement the order above using this parameter?
Ozy
Frank Warmerdam wrote:
> Ozy Sjahputera wrote:
>> Aha, so there is a way to set the photometric interpretation in
>> GTiff, even if this is to be done during file creation. Yes, I just
>> want to give a simple label for the bands in the new GTiff file I
>> created using Create().
>> I suspect the PHOTOMETRIC=RGB will have to be set in the parameter
>> char ** /papszParmList
>> /in Create()? Where do I set this parameter? Where can I find more
>> details on the format of /papszParmList?/
> Ozy,
> It is a NULL terminated list of strings. So something like:
> char *apszParmList[] = { "PHOTOMETRIC=RGB", NULL };
> will do the trick.
> Best regards,
