[Gdal-dev] Opening many HDF subdatasets at once
Peng Gao
pgao at esri.com
Thu Feb 8 11:10:33 EST 2007
Is there a limit on the number of HDF subdatasets can be opened at the
time? I run into a problem where if I open many subdatasets (~10), HDF
driver fails right way.
If I open less than many (~10), the
driver succeeds first, and but fails later when some opened subdatasets
are closed,
and some new ones are opened (the total is less than 10).
Any ideas?
Gao, Peng
