[Gdal-dev] gdaladdo with .rrd ignoring compress overviews?
Matt Wilkie matt.wilkie at gov.yk.ca
Thu Feb 8 17:59:56 EST 2007
> Erdas Imagine files don't support LZW.  RLC is the only supported
> compression (I think).
Thanks for clearing that up. I did some tests and it appears that
"gdal_translate -of hfa -co compress=anydarntextyouwant" always results
in RLC compression. This includes "compress=none", though "compress=no"
does yield no compression. I can't think of a use case for not
compressing though.
> Frankly, I don't know why it even used the RLC compression.  I don't
> see any support for the COMPRESS_OVERVIEW config option in the
> HFA/.img/.aux code.
I was going to submit changes to the docs to help others following my
same train of thoughts, but now I'm more confused. From
http://www.gdal.org/gdaladdo.html:
    Create an external compressed GeoTIFF overview file
    from the ERDAS .IMG file:
    gdaladdo --config COMPRESS_OVERVIEW DEFLATE erdas.img 2 4 8 16
But for me this creates embedded overviews.
The next example from the same page yields an error:
    > gdaladdo --config USE_RRD YES overtest3.jpg 3 9 27 81
    ERROR 6: The JPEG driver does not support update access to
    existing datasets.
    0...11...20...31...40...51...60...71...80...91...100 - done.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
