[Gdal-dev] Re: Building against Xerces 2.7.0 fails
Benoit Myard myardbenoit at gmail.com
Fri Feb 9 10:03:27 EST 2007
> [...] You will find two small patches attached to this mail which
> correct the compilation errors.
Oops, I mixed up the filenames on the command line ; here are the
correct patches. Sorry.
Benoit Myard
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070209/9f7f50a8/iom_error_cpp.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070209/9f7f50a8/ogrili1datasource_cpp.obj
