[Gdal-dev] Re: Building against Xerces 2.7.0 fails
Mateusz Loskot
mateusz at loskot.net
Wed Feb 14 09:41:14 EST 2007
Benoit Myard wrote:
>> [...] You will find two small patches attached to this mail which
>> correct the compilation errors.
> Oops, I mixed up the filenames on the command line ; here are the
> correct patches. Sorry.
Your patches look good to me as improving type safety and portability.
The code in the iom_error.cpp file looks like depending on GCC
feature of VLA.
The code original in ogrili1datasource.cpp uses buggy behavior of GCC
and strchr should get/return const or get/return non-const objects,
but not get const and return non-const.
Here is a longer story about strchr() behavior in GCC/libstdc++:
http://gcc.gnu.org/ml/libstdc++/2006-02/msg00086.html
http://gcc.gnu.org/ml/libstdc++/2006-02/msg00087.html
Frank,
If you don't mind I'd vote for applying these patches (and I can do it).
Cheers
Mateusz Loskot
http://mateusz.loskot.net
