[Gdal-dev] RE: ogr2ogr KML styling
Randy George rkgeorge at cadmaps.com
Wed Feb 14 13:47:40 EST 2007
I am experimenting with kml output for example:
"E:\Program Files\FWTools1.1.3\bin\ogr2ogr" -f KML
D:\CookInlet\Cook-Inlet\test.kml D:\CookInlet\Cook-Inlet\Seismic_lines.shp
The resulting set of kml <Placemark> looks like this:
  <Placemark>
    <description><![CDATA[
      <b>DESCRIPTIO:</b> <i>293U-39</i><br />
      <b>SHOTBY:</b> <i>OIL COMPANY</i><br />
   </description>
         <LineString><coordinates>-152.11768673515135,60.589764421552438
-152.11540114261703,60.592063085951288 ...</coordinates></LineString>
                        <Style>
                                    <LineStyle>
                                                <color>ff0000ff</color>
                                    </LineStyle>
                                    <PolyStyle>
                                                <fill>0</fill>
                                    </PolyStyle>
                        </Style>
  </Placemark>
This seems fine except that the default linestyle width doesn't show up on
my GoogleEarth view. I can manually add <width>4</width> to correct the
problem, but is there a way to change kml style output in ogr2ogr?
I could resort to a java runtime.exec() with a STDOUT => XMLReader but
wondered if there was a way to merge a style definition file using ogr2ogr.
Perhaps an xslt approach would be better.
Thanks
randy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070214/30a9deba/attachment.html
