[Gdal-dev] gdal_merge vs. gdalwarp
John Mitchell
mitchelljj98 at gmail.com
Sat Feb 24 12:01:33 EST 2007
I have found in comparing the speed between gdal_merge and gdalwarp that
gdal_merge mosaics tiles together more than twice as fast. If all I need to
do is mosaic tiles together that are the same resolution and keeping the
same projection, then what advantage is using gdalwarp? Also I noticed what
I think is a new utility on the gdal utilities page called
"nearblack<http://www.gdal.org/nearblack.html>- Convert nearly
black/white borders to exact value."
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070224/5977d204/attachment.html
