[Gdal-dev] Bug in TiffLib 3.8.2
SriRam Prasad Bhasker
SriRam.PrasadBhasker at rmsi.com
Sat Feb 24 05:04:25 EST 2007
while compiling the below warning message is being generated.
warning :: tif_getimage.c(2103) : warning C4550: expression evaluates to a
function which is missing an argument list
static tileContigRoutine
initCIELabConversion(TIFFRGBAImage* img)
static char module[] = "initCIELabConversion";
float *whitePoint;
float refWhite[3];
if (!img->cielab) {
img->cielab = (TIFFCIELabToRGB *)
_TIFFmalloc(sizeof(TIFFCIELabToRGB));
if (!img->cielab) {
TIFFErrorExt(img->tif->tif_clientdata, module,
"No space for CIE L*a*b*->RGB conversion
state.");
return NULL;
TIFFGetFieldDefaulted(img->tif, TIFFTAG_WHITEPOINT, &whitePoint);
refWhite[1] = 100.0F;
refWhite[0] = whitePoint[0] / whitePoint[1] * refWhite[1];
refWhite[2] = (1.0F - whitePoint[0] - whitePoint[1])
if (TIFFCIELabToRGBInit(img->cielab, &display_sRGB, refWhite) < 0)
"Failed to initialize CIE L*a*b*->RGB conversion
state.");
_TIFFfree(img->cielab);
return NULL;
return putcontig8bitCIELab;
the output LIB is not getting compiled when used with vc++.
cheers
s.p.bhasker
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070224/61cba2af/attachment.html
