[Gdal-dev] Bug 1384 on FWTools release 1.1.2 (GDAL 1.4.0beta2)
Dori
izzybitsie at gmail.com
Tue Jan 2 13:03:46 EST 2007
I have already tried to use gdal by downloading FWTools updated with beta2
and a problem I experienced with previous gdal version is still there(pls.
see below description of original problem).
ORIGINAL PROBLEM: running gdal_merge.py -pct -o output.tif -pct in1.tif
in2.tif where in*tif = geotiff images with one band and same color table,
gave me a full black out.tif.
This was reported as a bug and it was fixed according to bugzilla report for
1.4.0beta2.
You can find the input images here if you would like to give it a try:
http://www.mediamax.com/izzybitsie/Hosted/AS_GMSSO_00_20061122205634.tif
http://www.mediamax.com/izzybitsie/Hosted/AS_GMSNO_00_20061122205548.tif.gz
BUGZILLA REPORT
Updated colortable reading to look guess about the scaling problem, and
fix up on the fly if encountered. Like this:
int nColorCount, nMaxColor = 0;
GDALColorEntry oEntry;
poColorTable = new GDALColorTable();
nColorCount = 1 << nBitsPerSample;
for( int iColor = nColorCount - 1; iColor >= 0; iColor-- )
oEntry.c1 = panRed[iColor] / 256;
oEntry.c2 = panGreen[iColor] / 256;
oEntry.c3 = panBlue[iColor] / 256;
oEntry.c4 = 255;
poColorTable->SetColorEntry( iColor, &oEntry );
nMaxColor = MAX(nMaxColor,panRed[iColor]);
nMaxColor = MAX(nMaxColor,panGreen[iColor]);
nMaxColor = MAX(nMaxColor,panBlue[iColor]);
// Bug 1384 - Some TIFF files are generated with color map entry
// values in range 0-255 instead of 0-65535 - try to handle these
// gracefully.
if( nMaxColor > 0 && nMaxColor < 256 )
CPLDebug( "GTiff", "TIFF ColorTable seems to be improperly
scaled,
fixing up." );
oEntry.c1 = panRed[iColor];
oEntry.c2 = panGreen[iColor];
oEntry.c3 = panBlue[iColor];
oEntry.c4 = 255;
The problem file has been archived in data/geotiff/misc as:
Bug1384_8bit_colortable.tif
I checked geotiff.cpp downloaded with gdal1.4.0beta2 that includes code that
looks like the one above, but I don't see this fix in this code. Am I
looking at the wrong code?
Does anyone know if fix for this bug was really included in FWTools1.1.2?
If so, does anyone have an idea on why I am still getting a black output
image?
Is there any other way to compose these 2 images keeping the color table?
BIG TX
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070102/76053683/attachment.html
