[Gdal-dev] GDAL1.4.0RC1 test result: 'sn' is not recognized as an
internal or external command
Zhonghai Wang
zhonghaiw at gmail.com
Wed Jan 3 11:24:34 EST 2007
Hallo there,
first of all, thank you guys for the efforts on the new GDAL package.
I've tried today to compile the package under .NET 2.0 following these
steps:
1. compile GDAL;
2. cd to swig\csharp to compile the C# wrapper, at this step i got an error
message when performing the command namke /f makefile.vc:
Microsoft (R) Program Maintenance Utility Version 6.00.8168.0
Copyright (C) Microsoft Corp 1988-1998. All rights reserved.
sn -k gdal.snk
The command "sn" is not recognized as an internal or external command
NMAKE : fatal error U1077: 'sn' : return code '0x1'
Stop.
is the GDAL package not compatible with .NET 2.0?
thanks for any information.
Regards
Zhonghai
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070103/08e96a6c/attachment.html
