[Gdal-dev] error in csharp bindings for ogr/gdal
Frank Warmerdam
warmerdam at pobox.com
Fri Jan 5 15:18:37 EST 2007
Matthew Perry wrote:
> Hey folks,
> Checking out the latest cvs head, I'm having troubles getting the
> csharp bindings working. I'm using the Mono 1.2.2.1_1 installer on
> linux.
> I ran the following steps OK:
> make veryclean
> make interface
> make
> Indeed "libogrcsharp.la" does not exist nor do the other *.la files
> refered to in the dll config files.
Matthew,
I ran into the same problem. It seems the csharp build stuff as setup
currently is incompatible with use of libtool. I'd suggest configuring
--without-libtool.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
