[Gdal-dev] error in csharp bindings for ogr/gdal
    Tamas Szekeres
    szekerest at gmail.com
    Fri Jan  5 15:34:49 EST 2007
2007/1/5, Frank Warmerdam <warmerdam at pobox.com>:
> It seems the csharp build stuff as setup
> currently is incompatible with use of libtool.  I'd suggest configuring
> --without-libtool.
Exactly. As I can see, using the libtool build, the values of
LD_SHARED and SO_EXT would force to build the unmanaged part of the
wrapper to be statically linked that is definitely unsupported.
Best Regards,
