[Gdal-dev] Oblique_ vs Double_Stereographic
Maciej Sieczka
tutey at o2.pl
Sun Jan 7 10:52:22 EST 2007
Frank
GIS data created in ESRI software, projected in EPSG 3120,2172-2174,
have their PROJECTION specified as Double_Stereographic (eg. [1]).
However, GDAL and dependent software use
PROJECTION["Oblique_Stereographic"] for these systems. This leads to
mismatches during data exchange, eg. v.in.ogr claims the shapefile
projected in 2174, created with ESRI software, does not match a GRASS
location set up using the same code - due to unknown projection name
Double_Stereographic [2].
I don't know for other 13 sterea projections [3], but according to [4]
ESRI's Double_Stereographic is the same as GDAL's
Oblique_Steregraphic, and that seems to make sense for 3120,2171-2174.
Should Double_Stereographic be intepreted as Oblique_Steregraphic by
GDAL and friends?
Please read Paul Kelly's comments on grass-dev:
http://www.nabble.com/Re%3A--GRASS-user--problem-with-vi.in.ogr-tf2934543.html
The discussion started on grass-user:
http://www.nabble.com/problem-with-vi.in.ogr-tf2931526.html
[1]
Layer SRS WKT:
PROJCS["PUWG_65_Strefa_IV",
GEOGCS["GCS_Pulkovo_1942",
DATUM["Pulkovo_1942",
SPHEROID["Krasovsky_1940",6378245.0,298.3]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Double_Stereographic"],
PARAMETER["False_Easting",3703000.0],
PARAMETER["False_Northing",5627000.0],
PARAMETER["Central_Meridian",16.67222222222222],
PARAMETER["Scale_Factor",0.9998],
PARAMETER["Latitude_Of_Origin",51.67083333333333],
UNIT["Meter",1.0]]
[2]
No projection name! Projection parameters likely to be meaningless.
A datum name S-42 (Pulkovo_1942) was specified without transformation
parameters.
[3]
$ grep -c "proj=sterea " /usr/local/share/proj/epsg
18
(substract 4 deprecated of them)
[4]
http://udig.refractions.net/docs/api-geotools/org/geotools/ct/proj/Stereographic.html
