[Gdal-dev] Re: DXF to raster conversion
Maciej Sieczka tutey at o2.pl
Sat Jan 13 05:00:46 EST 2007
Grzegorz Wiktorowski wrote:
>>> I received DXF file and I need to convert to TIFF format. From
>>> description
>>> of gdal_rasterize it seems to me it does not read DXF file.
>> You can convert to eg. PS with 'pstoedit', then rasterize this in GIMP
>> or with ImageMagick's 'convert'.
> As far as I found on pstoedit's web site it converts PS to DXF. My
> source is DXF do I don't think pstoedit helps here.
You are correct. My bad.
>>> I didn't find any tool to convert from DXF to OGR vector formats also.
>> GRASS GIS has v.in.dxf module for DXF import and it can output to any
>> OGR supported vector with v.out.ogr.
>> If you go for GRASS, note there it has it's own tool for rasterising -
>> v.to.rast. Next use r.out.gdal to export into any GDAL supported format.
> OK. But GRASS does not runs on Windows OS, I'm affraid.
Please try the QGIS+GRASS package http://download.qgis.org/qgis/win32/
There are also updated builds available at
http://qgis.org/uploadfiles/testbuilds
It contains the vast majority of GRASS modules. QGIS is used for the GUI.
Maciek
