[Gdal-dev] running gdal_translate, gdaladdo,
and gdaltindex simultaneously
John Mitchell
mitchelljj98 at gmail.com
Mon Jan 15 11:27:45 EST 2007
I have set up 4 .bat files each which run the following over and over again:
file1.bat file2.bat
file3.bat
file4.bat
gdal_translate gdal_translate
gdaladdo gdaladdo
gdaladdo gdaladdo
gdaltindex gdaltindex
What I would like to do is run all 4 .bat files at the same time so as to
save time, but I am concerned that their may be a conflict since all 4 files
will be running gdaltindex to the same .shp file. What if say file1.bat and
file3.bat happen to call gdaltindex at the same time will they both fail to
update the .shp file; will only one update the .shp or will both of them
successfully update the .shp file. Is their any parameter that I should add
when running gdal_translate, gdaladdo or gdaltindex to make it more
efficient or stable?
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070115/68b9fbc7/attachment.html
