[Gdal-dev] running gdal_translate, gdaladdo, and gdaltindex simultaneously
Mon Jan 15 13:26:35 EST 2007
John Mitchell wrote:
> Hi,
> I have set up 4 .bat files each which run the following over and over again:
> file1.bat                        file2.bat
> file3.bat                           file4.bat
> gdal_translate               gdal_translate
> gdaladdo                      gdaladdo
> gdaladdo                          gdaladdo
> gdaltindex                    gdaltindex
> What I would like to do is run all 4 .bat files at the same time so as
> to save time, but I am concerned that their may be a conflict since all
> 4 files will be running gdaltindex to the same .shp file.  What if say
> file1.bat and file3.bat happen to call gdaltindex at the same time will
> they both fail to update the .shp file; will only one update the .shp or
> will both of them successfully update the .shp file.  Is their any
> parameter that I should add when running gdal_translate, gdaladdo or
> gdaltindex to make it more efficient or stable?
John,
This is indeed unsafe and could result in corruption of the index.  I
would suggest doing the gdal_translate, and gdaladdo "in parallel", but
doing the index creation in a single run afterwards. Index creation is
very fast compared to translation and adding overviews.
Note, if you are seeing surprisingly slow performance in gdal_translate
or gdaladdo it may be suffering from "cache thrashing", in which case
setting the GDAL_CACHEMAX environment variable to a reasonable size may
help.
eg
set GDAL_CACHEMAX=200
(for 200MB).
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
