[Gdal-dev] Maximum number of GCP at gdal_translate
Frank Warmerdam
warmerdam at pobox.com
Wed Jan 17 17:12:37 EST 2007
Hannes Isaak Reuter wrote:
> Dear Gdal people,
> anyone experience with the maximum number of GCPS one can specify at the
> commandline ?
Hannes,
In theory there is no practical limit. In practice you are limited by
whatever the maximum commandline length is on your system (or you can
use the --optfile switch to get some options from a file) and by the
limits on the number of gcps that will fit in a GeoTIFF tag if you are
copying to geotiff. I think geotiff will allow only something like
1000 gcps (64K / 48 bytes per gcp).
So, if you really want to have a lot of gcps, use --optfile to read them
from a file, and use an output format with no limit, like VRT.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
