[Gdal-dev] Buildbot reconfiguration
    Mateusz Loskot
    mateusz at loskot.net
    Thu Jan 18 17:35:57 EST 2007
Frank Warmerdam wrote:
> Mateusz Loskot wrote:
>> Hi,
>> I'm going to submit libpng/zlib updates, so first I wanted to have
>> buildbot running with tests, at least one builder.
>> It seems everything is OK, except suspicious results for OSR:
>> http://buildbot.osgeo.org:8500/athlonxp_linux_quick/builds/77/step-test/0
>> Running tests from osr/osr_ct_proj.py
>>   TEST: Proj: UTM_WGS84 ... skip
>>     PROJ.4 missing, transforms not available.
>>   TEST: Proj: NGO_Oslo_zone1_NGO ... skip
>>   TEST: Proj: MMRome1_MMGreenwich ... skip
>>   TEST: Proj: Bonne_WGS84 ... skip
>>   TEST: Proj: TPED_Mars ... skip
>> Frank, hobu, could you verify if it?
> Mateusz,
> I believe this is because PROJ.4 is not installed on the buildbot system.
> You could add it, but it is also helpful to have at least one builtbot
> instance running without it.  Generally "skips" are ok in the test suite.
Frank,
Thanks for the explanation.
I wasn't sure if something is wrong with GDAL_DATA or other stuff.
OK, I'll leave this one without PROJ.4.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
