[Gdal-dev] Buildbot reconfiguration
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 18 17:50:15 EST 2007
Mateusz Loskot wrote:
> Hi,
> I'm going to submit libpng/zlib updates, so first I wanted to have
> buildbot running with tests, at least one builder.
> It seems everything is OK, except suspicious results for OSR:
> http://buildbot.osgeo.org:8500/athlonxp_linux_quick/builds/77/step-test/0
> Running tests from osr/osr_ct_proj.py
> TEST: Proj: UTM_WGS84 ... skip
> PROJ.4 missing, transforms not available.
> TEST: Proj: NGO_Oslo_zone1_NGO ... skip
> TEST: Proj: MMRome1_MMGreenwich ... skip
> TEST: Proj: Bonne_WGS84 ... skip
> TEST: Proj: TPED_Mars ... skip
> Frank, hobu, could you verify if it?
Mateusz,
I believe this is because PROJ.4 is not installed on the buildbot system.
You could add it, but it is also helpful to have at least one builtbot
instance running without it. Generally "skips" are ok in the test suite.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
