[Gdal-dev] Visual Studio "Makefile" Project
Fri Jan 19 16:49:27 EST 2007
Simon Perkins wrote:
  > I guess this project file is relatively harmless, but I wonder if we're
> putting too many different parallel build systems into the GDAL source
> tree. There are already unix makefiles, Visual Studio makefiles, WinCE
> projects files, and now this one. In addition, there are externally
> maintained VS 2003 project files to build GDAL directly. And of course
> if you run VS 2005 (hey, this is 2007 after all...), then these project
> files all have to be converted to the new VS 2005 to use them, and then
> changes can't be committed back to the repository. Apart from the
> aesthetically unpleasing clutter, there's all the effort that goes into
> maintaining these distinct build systems and keeping them in sync with
> the source code.
Simon,
I'll say this in favor of this addition, at least it is just a small parent
project file and it will keep "up to date" as long as the standard
makefile.vc files work.
I think the windows ce build stuff has been segregated off in their own
directory
> - Creating a contrib or extras directory in the GDAL main directory
> where people can feel free to add builds scripts (and whatever else) for
> as many different systems as they like.
> - Creating a separate gdal-contrib SVN directory in parallel with gdal
> directory where extras can go.
I'm not adverse to either of the above, though it won't make it any
more likely that they are kept up to date.
> - Putting the effort into getting a true general purpose build system in
> place such as cmake, which could then ultimately replace all the other
> build scripts.
This would be nice, if it worked out smoothly and there was someone to
do it.  But I am dubious about both of those.  And a complete rework of
the build system is going to cause a lot of churn and pain.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
