[Gdal-dev] gdal install gdaladdo IReadBlock failed
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 23 00:02:51 EST 2007
Ryan Ollerenshaw wrote:
> But when running gdaladdo i still get the following error:
> ERROR 1: IReadBlock failed at X offset 0, Y offset 29
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 29
> ERROR 1: test.tif:DumpModeDecode: Not enough data for scanline 0
> ERROR 1: TIFFReadEncodedTile() failed.
> any ideas on what could be going wrong. I thought a reinstall of a
> newer version of gdal would fix this, but that does not seem to be the
> case.
Ryan,
It might well be an improperly written TIFF file that is causing the
problem. It might be helpful to have a "tiffinfo -m 10000 " report on
the file for which this problem is reported.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
