[Gdal-dev] Problem using gdal_translate on netcdf file
Hernán De Angelis
dhdeangelis.listas at gmail.com
Tue Jan 23 04:26:41 EST 2007
Andrew,
I tried this morning with one of the netCDF grids that come with the
GMT examples (ex02/HI_topo2.nc). I did:
gdal_translate -scale -7438 2804 0 255 -ot Byte netCDF:"HI_topo2.nc":z test.jpg
and works good for me. This command exported to a 8bit image while
rescaling to the max and min of the netCDF grid to 0 and 255. One must
be careful in selecting the appropriate netCDF dataset. You can
afterwards modify the colours in GIMP to make the image look nicer.
Cheers
Hernán
2007/1/22, Chase, Andrew <achase at mbari.org>:
> Thanks for the suggestion Hernán, I've already tried this (and tried it again just now to double check). When I set "-ot Byte" I still get a black image, this time in all formats including Gtiff, whereas before I got the vertical banding in Gtiff.
> Still searching...
> -Andrew
> ________________________________
> From: gdal-dev-bounces at lists.maptools.org [mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Hernán De Angelis
> Sent: Saturday, January 20, 2007 1:21 AM
> To: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] Problem using gdal_translate on netcdf file
> Your files are in Float32 format, try rescaling them to 8bit: gdal_translate -ot Byte
> 2007/1/20, Chase, Andrew <achase at mbari.org>:
> Hi All,
> I'm trying to convert a netcdf file to some an image format that I can use with imagemagick (tiff, jpg, png, anything will do). Unfortunately, I'm having some troubles getting the job done. When I try gdal_translate with any format other than Gtiff I get a completely black image. When I use the Gtiff format, I get a weird grayscale mutated version of my source file, with strange grainy vertical bands. When I open the netcdf file in OpenEV it looks perfectly normal, and I use the netcdf file for a lot of different data processing, so I feel confident that the data itself is good (if not the formatting of the data).
> I've placed a subsetted version of the translated image online to show what the resulting geotiff looks like, it's here:
> http://www.mbari.org/staff/achase/vdm/hrbath.tif <http://www.mbari.org/staff/achase/vdm/hrbath.tif>
> Maybe someone else has seen this same type of image problem?
> Here's the gdalinfo output:
> C:\workspace\vdm\resources\grids>gdalinfo NETCDF:"hrbath.nc":elevation
> Driver: netCDF/Network Common Data Format
> Size is 5001, 4001
> Coordinate System is `'
> Origin = (-125.000000000000000,38.000999999999998)
> Pixel Size = (0.000999800039992,-0.000999750062484)
> Metadata:
> NC_GLOBAL#creationDate=01/19/2007
> NC_GLOBAL#lastModified=01/19/2007
> NC_GLOBAL#Conventions=CF-1.0
> NC_GLOBAL#CreatedBy=VARS Data Mining Software - MBARI
> NC_GLOBAL#title=DEM Grid from hrbath.asc
> NC_GLOBAL#institution=MBARI
> NC_GLOBAL#creator_name=Andrew Chase
> NC_GLOBAL#keywords=dem bathymetry grid
> elevation#positive=up
> elevation#long_name=Elevation
> elevation#missing_value=-9.999900e+004
> elevation#units=meters
> latitude#units=degrees_north (+N/-S)
> longitude#units=degrees_east (+E/-W)
> Corner Coordinates:
> Upper Left (-125.0000000, 38.0010000)
> Lower Left (-125.0000000, 34.0010000)
> Upper Right (-120.0000000, 38.0010000)
> Lower Right (-120.0000000, 34.0010000)
> Center (-122.5000000, 36.0010000)
> Band 1 Block=5001x1 Type=Float32, ColorInterp=Undefined
> NoData Value=-99999
> Metadata:
> NETCDF_VARNAME=elevation
> And here's the translation I'm trying:
> C:\workspace\vdm\resources\grids>gdal_translate -of GTiff -a_nodata -99999 NETCD
> F:"hrbath.nc":elevation hrbath.tif
> Input file size is 5001, 4001
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> And the resulting gdalinfo output:
> C:\workspace\vdm\resources\grids>gdalinfo hrbath.tif
> Driver: GTiff/GeoTIFF
> Size is 5001, 4001
> Metadata:
> Corner Coordinates:
> Band 1 Block=5001x1 Type=Float32, ColorInterp=Gray
> NoData Value=-99999
> Metadata:
> Any ideas of what to try would be appreciated.
> -Andrew
> Andrew C. Chase
> Software Engineer
> Monterey Bay Aquarium Research Institute
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
> Hernán De Angelis
> Linux user # 397217
Hernán De Angelis
Linux user # 397217
