[Gdal-dev] src/dstnodata not effective for indexed colour
    Matt Wilkie
    matt.wilkie at gov.yk.ca
    Fri Jan 26 15:26:12 EST 2007
> It isn't possible for me to test this right now, but I would expect that
> for your indexed input file your -srcnodata value would be the INDEX
> value you want to be treated as "no data", rather than the RGB value
> associated with that index value.
Right you are Ed. Thanks!
At one point I did try using the index # with no apparent effect.
However on taking a close look, I found there are 2 index entries for
255,255,255, and in my tests I was specifying an index which is not used
  in the image by any pixels.
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
