[Gdal-dev] Does gdalinfo Bounding Box Information really match DTED
/ SRTM ?
Michael84
michael.timo.welsch at gmx.de
Tue Jan 30 02:43:49 EST 2007
I use gdalinfo to extract bounding box information of DTED L0&L1 (dt0, dt1)
as well as SRTM (hgt over bil+hdr+proj solution) data.
In both cases the reported corner points are not integer values as supposed.
Corner Coordinates: (DTED)
Upper Left ( -0.0041667, 49.0041667) ( 0d 0'15.00"W, 49d 0'15.00"N)
Lower Left ( -0.0041667, 47.9958333) ( 0d 0'15.00"W, 47d59'45.00"N)
Upper Right ( 1.0041667, 49.0041667) ( 1d 0'15.00"E, 49d 0'15.00"N)
Lower Right ( 1.0041667, 47.9958333) ( 1d 0'15.00"E, 47d59'45.00"N)
Center ( 0.5000000, 48.5000000) ( 0d30'0.00"E, 48d30'0.00"N)
Is this is a roundig bug of gdal or are the data sources just coded like
this ?
View this message in context: http://www.nabble.com/Does-gdalinfo-Bounding-Box-Information-really-match-DTED---SRTM---tf3140934.html#a8705213
Sent from the GDAL - Dev mailing list archive at Nabble.com.
