[Gdal-dev] RE: ogr2ogr geodatabase translation
Randy George
rkgeorge at cadmaps.com
Wed Jan 31 10:33:21 EST 2007
This question didn't seem go through to the list. Here's a second try.
I am attempting to translate some NHD data from
ftp://nhdftp.usgs.gov/SubRegions/ using ogr2ogr 1.4.0 in FWTools 1.1.3, but
having some problems.
The NHD data comes as ESRI geodatabase .mdb files. I was excited to see that
ogr2ogr now supportsESRI geodatabase mdb format and ran the following:
ogr2ogr -f PostgreSQL PG:"user=user dbname=NHD host=localhost
password=password port=5432" D:\NHD\NHDH0101\NHDH0101.mdb
The translation went smoothly without apparent error resulting in a set of
tables with geometry_columns entries:
"8012398";"''";"public";"Basin";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012493";"''";"public";"HYDRO_NET_Junctions";"wkb_geometry";"2";"32767";"GE
OMETRY"
"8009168";"''";"public";"NHDArea";"wkb_geometry";"2";"32767";"GEOMETRY"
"8009194";"''";"public";"NHDFlowline";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012333";"''";"public";"NHDLine";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012359";"''";"public";"NHDLineEventFC";"wkb_geometry";"2";"32767";"GEOMETR
Y"
"8012346";"''";"public";"NHDPoint";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012372";"''";"public";"NHDPointEventFC";"wkb_geometry";"2";"32767";"GEOMET
RY"
"8009181";"''";"public";"NHDWaterbody";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012385";"''";"public";"Region";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012436";"''";"public";"Subbasin";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012417";"''";"public";"Subregion";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012480";"''";"public";"Subwatershed";"wkb_geometry";"2";"32767";"GEOMETRY"
"8012467";"''";"public";"Watershed";"wkb_geometry";"2";"32767";"GEOMETRY"
However, several of the tables, not all, have empty wkb_geometry columns. In
addition a couple of tables have incompletely translated wkb_geometry with
only some rows containing data.
I then tried using an ODBC DSN:
ogr2ogr -f PostgreSQL -update -overwrite PG:"user=user dbname=NHD
host=localhost password=password port=5432" PGeo:NHD Basin
but the Basin.wkb_geometry was still empty. The Access mdb file appears to
have long binary data in a Shape column.
Perhaps individual tables need to be translated with a specified geom
column?
Is a log generated by an ogr2ogr translation?
Thanks
randy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20070131/de21492e/attachment.html
