[Gdal-dev] need help compiling GDAL with HDF5 support
Daniel.Gillespie at noaa.gov
Wed Jan 31 10:59:32 EST 2007
Hello. I am trying to ultimately trying to build Grass with the ability
to readHDF5 files. I tried to compile GDAL with HDF5 support and ran
into problems in the compilation process. I believe that the HDF5 build
process was successful, because the HDF5 utilities like gif2h5 are now
available on my system.
Any advice would be greatly appreciated!
Many thanks,
Dan Gillespie
Here are some specifics:
Red Hat Linux
GDAL: gdal-cvs-2006.03.29
HDF5: hdf5-1.6.5
Here is the configuration file:
./configure --with-hdf5=/usr/local/hdf5/hdf5-1.6.5/hdf/bin --with-php
Here is some of the output items from the configure step that appears to
relate
to HDF5:
checking for SDreaddata in -lmfhdf... no
checking for H5Fopen in -lhdf5... no
GDAL is now configured for i686-pc-linux-gnu
Installation directory: /usr/local
C compiler: gcc -O2
C++ compiler: g++ -O2
LIBTOOL support: yes
LIBZ support: external
GRASS support: no
CFITSIO support: no
PCRaster support: internal
NETCDF support: no
LIBPNG support: external
LIBTIFF support: external
LIBGEOTIFF support: internal
LIBJPEG support: external
LIBGIF support: external
OGDI support: no
HDF4 support: no
HDF5 support: yes
KAKADU support: no
JASPER support: no
ECW support: no
MrSID support: no
POSTGRESQL support: yes
MySQL support: no
XERCES support: no
ODBC support: no
OCI support: no
SDE support: no
DODS support: no
SQLite support: no
DWGdirect support no
PANORAMA GIS support: no
GEOS support: no
Statically link PROJ.4: no
Traditional Python: yes
NG SWIG Bindings: php
enable OGR building: yes
When I got to the make step, there were lots of errors relating to HDF5:
hdf5dataset.cpp:58:18: hdf5.h: No such file or directory
In file included from hdf5dataset.cpp:62:
hdf5dataset.h:59: error: ISO C++ forbids declaration of `hsize_t' with
no type
hdf5dataset.h:59: error: expected `;' before '*' token
hdf5dataset.h:60: error: `hid_t' does not name a type
hdf5dataset.h:61: error: `hid_t' does not name a type
hdf5dataset.h:67: error: `herr_t' does not name a type
hdf5dataset.h:80: error: `hid_t' does not name a type
hdf5dataset.h:81: error: `hid_t' does not name a type
hdf5dataset.h:82: error: `hid_t' does not name a type
hdf5dataset.h:101: error: `hid_t' has not been declared
hdf5dataset.h:101: error: ISO C++ forbids declaration of `parameter'
with no type
hdf5dataset.h:102: error: expected `;' before '(' token
hdf5dataset.cpp: In constructor `HDF5Dataset::HDF5Dataset()':
hdf5dataset.cpp:109: error: `hHDF5' was not declared in this scope
hdf5dataset.cpp:110: error: `hDatasetID' was not declared in this scope
hdf5dataset.cpp:111: error: `hGroupID' was not declared in this scope
hdf5dataset.cpp:109: warning: unused variable 'hHDF5'
hdf5dataset.cpp:110: warning: unused variable 'hDatasetID'
hdf5dataset.cpp:111: warning: unused variable 'hGroupID'
hdf5dataset.cpp: In destructor `virtual HDF5Dataset::~HDF5Dataset()':
hdf5dataset.cpp:123: error: `hHDF5' was not declared in this scope
hdf5dataset.cpp:124: error: `H5Fclose' was not declared in this scope
hdf5dataset.cpp:124: warning: unused variable 'H5Fclose'
hdf5dataset.cpp:125: error: `hGroupID' was not declared in this scope
hdf5dataset.cpp:126: error: `H5Gclose' was not declared in this scope
hdf5dataset.cpp:126: warning: unused variable 'H5Gclose'
hdf5dataset.cpp: At global scope:
hdf5dataset.cpp:146: error: `GDALDataType HDF5Dataset::GetDataType' is
not a static member of `class HDF5Dataset'
hdf5dataset.cpp:146: error: `hid_t' was not declared in this scope
hdf5dataset.cpp:147: error: expected `,' or `;' before '{' token
hdf5dataset.cpp:183: error: `const char*HDF5Dataset::GetDataTypeName' is
hdf5dataset.cpp:183: error: `hid_t' was not declared in this scope
hdf5dataset.cpp:184: error: expected `,' or `;' before '{' token
hdf5dataset.cpp: In static member function `static GDALDataset*
HDF5Dataset::Open(GDALOpenInfo*)':
hdf5dataset.cpp:244: error: `H5Fis_hdf5' was not declared in this scope
hdf5dataset.cpp:244: warning: unused variable 'H5Fis_hdf5'
hdf5dataset.cpp:261: error: 'class HDF5Dataset' has no member named 'hHDF5'
hdf5dataset.cpp:262: error: `H5F_ACC_RDONLY' was not declared in this scope
hdf5dataset.cpp:263: error: `H5P_DEFAULT' was not declared in this scope
hdf5dataset.cpp:263: error: `H5Fopen' was not declared in this scope
hdf5dataset.cpp:264: error: 'class HDF5Dataset' has no member named 'hHDF5'
hdf5dataset.cpp:269: error: 'class HDF5Dataset' has no member named
'hGroupID'
hdf5dataset.cpp:269: error: 'class HDF5Dataset' has no member named 'hHDF5'
hdf5dataset.cpp:269: error: `H5Gopen' was not declared in this scope
hdf5dataset.cpp:270: error: 'class HDF5Dataset' has no member named
'hGroupID'
hdf5dataset.cpp:262: warning: unused variable 'H5F_ACC_RDONLY'
hdf5dataset.cpp:263: warning: unused variable 'H5P_DEFAULT'
hdf5dataset.cpp:263: warning: unused variable 'H5Fopen'
hdf5dataset.cpp:269: warning: unused variable 'H5Gopen'
hdf5dataset.cpp: In member function `void
HDF5Dataset::DestroyH5Objects(HDF5GroupObjects*)':
hdf5dataset.cpp:308: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:309: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:396: error: `herr_t' does not name a type
hdf5dataset.cpp:554: error: `herr_t' does not name a type
hdf5dataset.cpp: In member function `CPLErr
HDF5Dataset::CreateMetadata(HDF5GroupObjects*, int)':
hdf5dataset.cpp:683: error: `hid_t' was not declared in this scope
hdf5dataset.cpp:683: error: expected `;' before "hGroupID"
hdf5dataset.cpp:684: error: expected `;' before "hDatasetID"
hdf5dataset.cpp:686: error: `herr_t' was not declared in this scope
hdf5dataset.cpp:686: error: expected `;' before "ret"
hdf5dataset.cpp:700: error: `H5G_GROUP' was not declared in this scope
hdf5dataset.cpp:702: error: `hGroupID' was not declared in this scope
hdf5dataset.cpp:702: error: `hHDF5' was not declared in this scope
hdf5dataset.cpp:702: error: `H5Gopen' was not declared in this scope
hdf5dataset.cpp:704: error: `ret' was not declared in this scope
hdf5dataset.cpp:705: error: `HDF5AttrIterate' was not declared in this scope
hdf5dataset.cpp:705: error: `H5Aiterate' was not declared in this scope
hdf5dataset.cpp:706: error: `H5Gclose' was not declared in this scope
hdf5dataset.cpp:705: warning: unused variable 'HDF5AttrIterate'
hdf5dataset.cpp:705: warning: unused variable 'H5Aiterate'
hdf5dataset.cpp:706: warning: unused variable 'H5Gclose'
hdf5dataset.cpp:711: error: `H5G_DATASET' was not declared in this scope
hdf5dataset.cpp:713: error: `hDatasetID' was not declared in this scope
hdf5dataset.cpp:713: error: `H5Dopen' was not declared in this scope
hdf5dataset.cpp:716: error: `ret' was not declared in this scope
hdf5dataset.cpp:717: error: `HDF5AttrIterate' was not declared in this scope
hdf5dataset.cpp:717: error: `H5Aiterate' was not declared in this scope
hdf5dataset.cpp:718: error: `H5Dclose' was not declared in this scope
hdf5dataset.cpp:717: warning: unused variable 'HDF5AttrIterate'
hdf5dataset.cpp:717: warning: unused variable 'H5Aiterate'
hdf5dataset.cpp:718: warning: unused variable 'H5Dclose'
hdf5dataset.cpp:700: warning: unused variable 'H5G_GROUP'
hdf5dataset.cpp:702: warning: unused variable 'H5Gopen'
hdf5dataset.cpp:711: warning: unused variable 'H5G_DATASET'
hdf5dataset.cpp:713: warning: unused variable 'H5Dopen'
hdf5dataset.cpp:686: warning: unused variable 'herr_t'
hdf5dataset.cpp: In member function `HDF5GroupObjects*
HDF5Dataset::HDF5FindDatasetObjectsbyPath(HDF5GroupObjects*, char*)':
hdf5dataset.cpp:742: error: `H5G_DATASET' was not declared in this scope
hdf5dataset.cpp:742: warning: unused variable 'H5G_DATASET'
HDF5Dataset::HDF5FindDatasetObjects(HDF5GroupObjects*, char*)':
hdf5dataset.cpp:778: error: `H5G_DATASET' was not declared in this scope
hdf5dataset.cpp:778: warning: unused variable 'H5G_DATASET'
HDF5Dataset::HDF5ListGroupObjects(HDF5GroupObjects*, int)':
hdf5dataset.cpp:823: error: `H5G_GROUP' was not declared in this scope
hdf5dataset.cpp:830: error: `H5G_DATASET' was not declared in this scope
hdf5dataset.cpp:836: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:837: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:838: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:843: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:844: error: 'struct HDF5GroupObjects' has no member
named 'paDims'
hdf5dataset.cpp:868: error: 'class HDF5Dataset' has no member named
'GetDataTypeName'
hdf5dataset.cpp:869: error: 'struct HDF5GroupObjects' has no member
named 'native'
hdf5dataset.cpp:830: warning: unused variable 'H5G_DATASET'
HDF5Dataset::ReadGlobalAttributes(int)':
hdf5dataset.cpp:889: error: `H5G_GROUP' was not declared in this scope
hdf5dataset.cpp:893: error: `hHDF5' was not declared in this scope
hdf5dataset.cpp:893: warning: unused variable 'hHDF5'
hdf5dataset.cpp:898: error: `hGroupID' was not declared in this scope
hdf5dataset.cpp:898: error: `hHDF5' was not declared in this scope
hdf5dataset.cpp:898: error: `H5Gopen' was not declared in this scope
hdf5dataset.cpp:904: error: `H5Aget_num_attrs' was not declared in this
scope
hdf5dataset.cpp:906: error: `hsize_t' was not declared in this scope
hdf5dataset.cpp:906: error: expected primary-expression before ')' token
hdf5dataset.cpp:906: error: `H5Gget_num_objs' was not declared in this scope
hdf5dataset.cpp:913: error: `HDF5CreateGroupObjs' was not declared in
this scope
hdf5dataset.cpp:913: error: `H5Giterate' was not declared in this scope
hdf5dataset.cpp:913: warning: unused variable 'HDF5CreateGroupObjs'
hdf5dataset.cpp:913: warning: unused variable 'H5Giterate'
hdf5dataset.cpp:889: warning: unused variable 'H5G_GROUP'
hdf5dataset.cpp:898: warning: unused variable 'hHDF5'
hdf5dataset.cpp:898: warning: unused variable 'H5Gopen'
hdf5dataset.cpp:904: warning: unused variable 'H5Aget_num_attrs'
hdf5dataset.cpp:906: warning: unused variable 'hsize_t'
hdf5dataset.cpp:906: warning: unused variable 'H5Gget_num_objs'
make[2]: *** [../o/hdf5dataset.o] Error 1
make[2]: Leaving directory
`/root/grassinst/software/gdal-stuff/gdal-cvs-2006.03.29/frmts/hdf5'
make[1]: *** [hdf5-install-obj] Error 2
make[1]: Leaving directory
`/root/grassinst/software/gdal-stuff/gdal-cvs-2006.03.29/frmts'
make: *** [frmts-target] Error 2
