[Gdal-dev] support for python 2.5.1
John Cartwright
John.C.Cartwright at noaa.gov
Mon Jul 2 15:50:13 EDT 2007
Thanks Frank, you're right on target. I do have multiple versions on
this system and thought I had accounted for that w/ environment
variables, but realize now that I had different settings for "configure"
step than for the "make" step.
I appreciate the suggestion!
-- john
Frank Warmerdam wrote:
> John,
> Generally speaking this means that the gdal bindings were built against
> a different version of python than you are using to load it. Is there
> any chance you have more than one python installed on these systems?
> Best regards,
