[Gdal-dev] C# Dataset not calling GDALClose()?
Tamas Szekeres szekerest at gmail.com
Wed Jul 11 11:37:02 EDT 2007
Frank,
OGRCleanupAll() is not exposed to SWIG right now. Should we add this
function to the interface?
Best regards,
Tamas
2007/7/11, Frank Warmerdam <warmerdam at pobox.com>:
> Richard Matsunaga wrote:
> > Thanks Tamas, I didn't look deep enough to see what was happening in the C++
> > code for Dataset.
> > My problem is that our application is an ASP.NET web site and as soon as a
> > class instantiates a GDAL or OGR object, the GDAL dll gets locked and is
> > only released after some long period of idle time or if iisreset is called.
> > This makes updating GDAL (or just republishing the entire website) a bit of
> > a pain. I was initially worried that there may be a memory leak in there as
> > well, but that seems to not be the case.
> > The problem is easily reproduced using NUnit as well. Any test case that
> > uses a GDAL resource will lock the GDAL dll as well.
> > I just tried calling Ogr.RegisterAll() and it is the cause of the lock on
> > the dll. There seems to be no way of releasing resources initialized by
> > RegisterAll(). Not surprisingly, this behaviour is also flagged as a memory
> > leak (albeit a small one) by DevPartner when using OGR in an application.
> Richard / Tamas,
> I'm not clear on what this "DLL locking" is all about, but at the C
> level there is an OGRCleanupAll() function which will deregister OGR
> drivers as well as cleanup some other memory allocations.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
