[Gdal-dev] C# Dataset not calling GDALClose()?
Richard Matsunaga
richard.matsunaga at waypointinfo.com
Wed Jul 11 12:07:48 EDT 2007
This would likely help me out a great deal, as well as anyone using GDAL
inside of an ASP.NET web site.
Cheers,
Richard
> -----Original Message-----
> From: gdal-dev-bounces at lists.maptools.org
> Frank,
> OGRCleanupAll() is not exposed to SWIG right now. Should we
> add this function to the interface?
> Best regards,
> Tamas
> 2007/7/11, Frank Warmerdam <warmerdam at pobox.com>:
> > Richard Matsunaga wrote:
> > > Thanks Tamas, I didn't look deep enough to see what was
> happening in
> > > the C++ code for Dataset.
> > > My problem is that our application is an ASP.NET web site and as
> > > soon as a class instantiates a GDAL or OGR object, the
> GDAL dll gets
> > > locked and is only released after some long period of
> idle time or if iisreset is called.
> > > This makes updating GDAL (or just republishing the entire
> website) a
> > > bit of a pain. I was initially worried that there may be a memory
> > > leak in there as well, but that seems to not be the case.
> > > The problem is easily reproduced using NUnit as well. Any
> test case
> > > that uses a GDAL resource will lock the GDAL dll as well.
> > > I just tried calling Ogr.RegisterAll() and it is the cause of the
> > > lock on the dll. There seems to be no way of releasing resources
> > > initialized by RegisterAll(). Not surprisingly, this behaviour is
> > > also flagged as a memory leak (albeit a small one) by
> DevPartner when using OGR in an application.
> > Richard / Tamas,
> > I'm not clear on what this "DLL locking" is all about, but at the C
> > level there is an OGRCleanupAll() function which will
> deregister OGR
> > drivers as well as cleanup some other memory allocations.
> > Best regards,
> > I set the clouds in motion - turn up | Frank Warmerdam,
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
